10-737491-001 socket
------Question for 10-737491-001 Please Put your question below------
Does anyone have more information about Note 3 in the datasheet?
“WHEN CHOOSING A NEW PCB THICKNESS, A NEW PART NUMBER MAY NEED TO BE ASSIGNED, DEPENDING ON THE REQUIREMENTS FOR DIM ‘D’ OR DIM ‘H’.”
My PCB thickness is 1.6 mm, so I’m not sure whether a suitable product is available for this thickness.
Could you also provide information about the lead time for ordering from Taiwan?
Thank you!
Greetings,
It can be understood that a thicker PCB may require a shorter dimension ‘H’ if the overall stack height of a mated connector system is fixed, or that the 2.6mm dimension ‘D’ might need to be extended for very thick PCBs.
So long as the mechanical dimensions of the connector are taken into account in your design, use of a thinner PCB would not seem to present a problem from the connector’s perspective. Issues of board flexure as a result of mating forces may become troublesome however, and should be considered.
Items in stock at DigiKey typically ship within 24 hours of order, with international transit times depending on the shipment method chosen and local conditions. Please see the delivery information page for more details.
Hi Rick, I would like to ask for the maximum acceptable vertical tolerance during assembly between 10-737491-001 socket and its corresponding pin? thank you!
I’m not finding any specification describing maximum axial misalignment. Understanding that the PCB fabrication processes drilling the holes into which they’d be inserted are usually accurate to within a thousandth or two, one may expect that angular misalignment or tiling of the contacts within the mounting holes is likely to be of similar or greater concern.
Thaks Rick, yes that is also our concer when assembly.
Besides, could you provide the recommended minimum and maximum pin insertion depths for this socket? we don’t know to select a suitable pin length.
In addition, could you please confirm whether the pin can be inserted into the socket from both directions or pass completely through the socket? Thank you!
Examining the drawing above can offer insights in response to questions of this kind.
The isometric and cross-sectional views together show that the passage through the connector is not closed-ended, allowing a mating pin to pass completely through or potentially be inserted from both ends.
Regarding recommended insertion depth, it can be seen that the inner contact is curved in the cross-section view, part of which will be distorted into a flat form by the inserted pin, with the necessary contact forces being supplied as a result of this distortion.
It can be reasonably inferred that a pin insertion depth sufficient to ensure full use of the available contact area would be recommended. A crude illustration of the concept is below.
Selection of a suitable pin length seems likely to be a question of other mechanical factors within your design, as well as the selection of part numbers that is readily available through distribution; from a procurement standpoint it is usually preferable to select products that are commonly available, rather than bespoke items that are only available by special request.
