------Question for 10029449-001RLF Please Put your question below------
I need a replacement for female micro hdmi port on my Raspberry Pi 5.
Will the 10029449-001rlf fit in? or do you guys have any suggestion of which particular would fit as replacement?
Hi,
10029449-001RLF would not work as a replacement as it is a standard HDMI and not a micro .
Here are some micro HDMI female that might be better suited for your application (click here)
can you recommend me a specific Mfr Part # that would suit the Raspberry Pi 5 based from the sorted list you gave?
Hi angelito_tolentino31,
I have not found any information on the specific micro HDMI part used in the RPi 5 nor any information regarding any specific part which would work to replace it.
If you could identify the part number used in the original and find a drawing of its dimensions (I was not able to find that), perhaps we could find something using the drawings that could be hacked in without too much trouble.
Looking at the possible options we have here, there does not appear to be any which look exactly like the ones on the RPi 5. We should have drawings available for most, if not all of the ten options in the above link on their respective product detail pages in the “Documents & Media” section. If you take a look at those drawings and compare to the one on the Pi, maybe you might find one to be close enough that you could try to hack it in.
