Can you help me. 17-638393-5-ND i have this connector. I need this connector correct fit female terminal pin
Hello akshaytjayaprakash28,
Welcome to the DigiKey TechForum!
I found 17-638551-2-ND which is compatible with the housing you are looking at.
This specific contact is meant to be crimped to 22awg wire, I would confirm that the wire you’re using is 22awg before placing an order for this specific socket.
Wire Size .5-.75 mm2| 20-18
AWG (TE064-SKT2) this is correct ….? ![]()
If your wire size is 18 or 20 awg, then yes, contact 17-638551-1CT-ND would be the correct sized contact for that wire size.
