For the Sparkfun Electronics part number 18081 cable assembly, what is the pitch of the male pins? What are the pin dimensions?
@wrasse12, welcome to the DigiKey TechForum!
You can find the datasheet for 18081 at the link below:
Datasheet
According to the datasheet, the connector housing used is JST ZHR-6, with a pitch of 1.5 mm.
For the male pin end of the cable it looks to be a 2.54mm pitched connector.
Per the drawing it would be individual positions.
Sparkfun indicates that the pins would be compatible with a bread board, so I would think that it would match the general dimensions of the below item.
A26962-ND - Housing
7-87499-2 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
A33420CT-ND - Contact
5-102095-4 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
