------Question for CHN-SLD802
Please Put your question below------
I ordered this thinking it was a115VAC unit, but it’s 220VAC.
Is it possible to reconfigure it for 115VAC? (If I also change the plug).
Welcome to the DigiKey TechForum. There is no input voltage selector to change voltages for this solder iron. I would take a look at DigiKey part 1568-14456-ND as an option that uses 115vac with a NEMA 5-15P connector on the end.
Thanks! I disassembled my iron and didn’t see any obvious solutions,cso ordered a 115VAC unit, but thanks for the suggested alternative.
