Is this motor a D shaft or does it have a keyway? Product image shows a D shaft but drawing shows a keyway.
Hello mmosher, welcome to the TechForum! iSL products informed us that the drawing on the datasheet is correct. The part does have a keyed shaft. At this moment, iSL doesn’t have a product in stock with similar performance or same shaft size that has a D-flat as seen in the photo. Are there parameters you can change for your application?
