281DL1LP-11-000B Alternative
281DL1LP11000B is a fan from Ecofit Etri which Digi-Key does not carry.
P15628-ND is a fan Digi-Key carries with similar specs.
Digi-Key Part Number P15628-ND N/A
Manufacturer Part Number 2410ML-04W-B20-E00 281DL1LP11000B
Manufacturer NMB Technologies Corporation Ecofit Etri
Description FAN AXIAL 60X25MM 12VDC WIRE FAN AXIAL 60X25MM 12VDC WIRE
Voltage - Rated 12VDC 12VDC
Size / Dimension Square - 60mm L x 60mm H Square - 60mm L x 60mm H
Width 25.00mm 25.00mm
Air Flow 16.9 CFM (0.473m³/min) 16.748 CFM (0.473m³/min)
Static Pressure 0.128 in H2O (31.9 Pa) 0.128 in H2O (31.9 Pa)
Bearing Type Ball Ball
Fan Type Tubeaxial Tubeaxial
Noise 28.0 dB 26.5 dB
RPM 3600 RPM 3100 RPM
Termination 2 Wire Leads 2 Wire Leads
For more information on P156280-ND, check out the datasheet.
