3.50mm Mono Connector Solder Eyelet - no ground?
------Question for 54-00171 Please Put your question below------
There appears to be a 1.5mm positive connector on this panel mount 3.5mm, but there is no corresponding 1.5mm connector on the cylinder where the diagram references contact B?
How does one ground this?
Do I simply solder directly onto the cylinder?
Welcome to the TechForum.
Yes you are exactly right. The datasheet shows the B and A termination like you said for the A and B position mating plug.
54-00171.pdf
Thank you
Ryan
