3 Position Header 2mm
------Question for S3B-PH-K-S Please Put your question below------
Hi! Do they make this product without the metal pins(fingers) in it? Thanks! Brad.
Hello @bradadams682
Unfortunately, JST does not make just the plastic housing for the male header pins. The only housing JTS has is the mating connector to S3B-PH-K-S which is PHR-3 and that housing is for the female socket contacts.
