314-1187-ND
is this for a 4mm banana plug? and what is the ID of the wire hole? Thanks ~Bob~
The datasheet does indicate it indeed is for a 4mm banana plug.
The 18-22AWG wire size for the wire hole would indicate a little larger than 0.04 inch diameter (1mm metric)
