Just want to ask "381-3397-ND Total Replacement for W4E315-CA05-02 " can be total replacement?
Hello sales111,
We do not carry the W4E315-CA05-02, but I looked at the W4E315-CA05-51. This fan has a frame around the fan, and is 397mm diameter.
The 381-3397-ND fan is the blades and the motor, without a frame, and is 312mm diameter.
So this would not be a direct replacement. You will have to check the datasheet to determine if the 381-3397-ND fan will work in your application.
