399-R75MN31505030J-ND
------Question for R75MN31505030J Please Put your question below------
Looking for the lead length, which is a “lead and packaging code” in the data sheet. Need >4.
Thank you for your inquiry and welcome to the community.
The version you’re looking at would have 25mm leads. I’ve highlighted all the options that would have your required dimensions.
Can you confirm that you do not have the 30mm length (40)?
The (40) version of this with the 30mm length leads is not something that we carry, it is not currently a valid part number in our system. Theoretically, it should be R75MN31504030J or R75MN315040xxJ with “xx” being a given internal code from KEMET, but I didn’t see any version of this in our system unfortunately.
