------Question for 3792-LM-Q Please Put your question below------
I was wondering approximately how many sticks come in the 11lb box?
Greetings,
Using the density of 1.01g/cc indicated in the SDS, indicated 5/8"x8" stick size and some conversion factors I’m coming up with about 123 sticks/box. Seems reasonable, but math errors do happen…
OK. Thank you it was showing 1.02 Ibs on the data sheet so I was guessing 10 sticks. So Unit weight is 1.01g/cc?
It also lists it as 0.036 lb/in3 (Cubic inch). For the 5/8”X8” sticks, that figures to about 125, with some rounding, so that must be in the ballpark.
