5 Pint Flat Connector ID
Hi, any one able to identify this guy? Thanks!
Hi jhdigikey,
Welcome to the DigiKey TechForum community.
I’m not sure what exact one in that picture is but I found something like it in WM14763-ND. This ones is also 5 pin in 1 row. This one has a 0.100" (2.54mm) pitch between center of each pin. This is a receptacle with female sockets on the inside and meant for 24AWG wire with IDC termination style.
Please verify its full parameters by looking through the data sheet to make sure it will work for you as needed.
You can review other similar options here: Free Hanging, Panel Mount | Rectangular Connectors | Electronic Components Distributor DigiKey
Be weary of the pitch and other sagnificant parameters when filtering.
Hope that helps.
Regards,
Here is the Male side:
