568-S12ZVM-EFP-ND E water pump controller software support
Dear DigiKey Technical Support Team,
We are planning to procure a motor controller development board for developing an 80 W automotive e-water pump controller.
We require technical guidance in selecting a suitable development board and implementing the control software according to our application requirements.
Our key requirements are:
  1. Support for three-phase BLDC/PMSM motor control.
  2. Implementation of a Field-Oriented Control (FOC) algorithm or a suitable BLDC control algorithm.
  3. Support for LIN and PWM interfaces for pump speed control and communication with the vehicle system.
  4. Custom firmware development based on our motor and pump specifications.
  5. Software development tools, IDE, firmware libraries, sample code, and reference projects.
  6. Support for motor parameter configuration, current sensing, speed control, fault detection, and protection functions.
  7. Technical documentation and guidance for firmware development, debugging, and testing.
Could you please recommend a suitable development board available through DigiKey and confirm whether software development support, example firmware, and technical assistance are available?
We would also appreciate guidance on whether the proposed board supports both LIN communication and PWM speed control, along with FOC-based BLDC/PMSM control
Hello @Vignesh_Kumar
This is a wonderful project!
My recommendation is to locate several demonstration boards and then work backwards to identify and refine your requirements. For example, the STMicroelectronics STEVAL-PTOOL4A is one of several candidates.
This will allow you to:
  • Explore power electronics
  • Explore the interface between the power side and the STM32 microcontroller
  • Reverse engineer the demonstration software
  • Evaluate the microcontroller’s capabilities against your team’s requirements.
Best wishes in your studies.
P.S. Also review pages such as this and this.
P.P.S. This related eval board may be more automotive.
