61500190550 s 타입은 없나요?
------Question for 61500190550 Please Put your question below------
Welcome to the DigiKey TechForum. You question according to
Google translates to "Is there no type? " Can you provide more detail as to what information you are seeking for part 61500190550 which is a non-stock item with a 70 piece minimum order quantity.
제가 필요로 하는 물품은 3M제품으로 Scotch-brite, Replacement Radial Bristle Brush: Type S, 8 inch Dia x 1 in Wd, 1 1/4 in Arbor, 70 st/ Pack 입니다.
여기에 해당하는 제품이 어떤것인지 사진으로 제시 부탁합니다.
Text
3M 품번으로는 7100138340 이라고 합니다
Thanks for the information. I verified, the item you are looking for is DigiKey part 3M160321-ND. This is the 8 inch replacement disc that comes in a pack of 70 .
