71139 Bit Holder
------Question for 71139 Please Put your question below------
What is Tip Size for 71139-ND? Will it able to hold 4 mm Micro Bits?
This part can only fit 1/4” bits, unfortunately this will not work with 4mm bits.
Hi ssankdasariya,
If you are looking for an adapter which converts a 1/4" driver to handle 4mm Micro Bits, here are a couple of options:
  • 75802 4mm Micro Bit to 1/4 drive insert bit adapter – magnetic
  • 75803 4mm Micro Bit to 1/4 drive insert bit adapter – non-magnetic
Hi, will 75902 also fit 4mm micro bits into 1/4” tools? I need to use the micro bit into a drill that only accepts 1/4” bits.
