We have purchased 6 724 mo Workstation Monitor. Found out once they got here that the connector size for the banana phono was a 3.5mm which doesn’t work for us. Do you have a 732 dual remote with a 4mm banana phono connection. Or does the 724 plus come with a 4mm banana phono connection?
Hello Johnny,
Welcome to our community and thank you for contacting DigiKey Technical support.
I am sorry to inform you that we have no way of adjusting the filters for banana plug in the ESD monitors.
I asking if the 724 mo Workstation Monitor or 724 Plus comes with a 4mm size banana connector? Because the current size of the 724 mo Workstation Monitor is a size 3.5mm.
The workstation monitors do not come with a 4mm size banana connector. If there was the option for it, the datasheet would have a note for it.
