74477020 Test conditions
------Question for 74477020 Please Put your question below------
Dear DigiKey Support,
Could you please clarify the correct test conditions for the inductor 74477020? The datasheet specifies 100 kHz, 250 mV, while 1 kHz is listed in “Inductance Frequency - Test” of Digikey.
If 1 kHz is correct, is 250 mV still correct too?
Thanks in advance!
Respectfully,
Arthur
Greetings,
The manufacturer’s product specifications should be considered authoritative in all instances.
Information presented via the DigiKey product search is aggregated and maintained using a large number of information sources, through processes which unfortunately remain subject to error.
In cases where information present on the DigiKey site is found to be at variance with the manufacturer’s documentation, the “Report Product Information Error” button on the respective product page can be used to call attention to the matter.
