Hi i am purchasing a part Ac-Dc converter UT1404-7 30.5V,500W but the image is showing 48V , so i am confuse that ,is this the same part as described in description or showing description on part image?
Hello ecomsolution2022,
The photos of the products are a representation only.
You can check the datasheet to verify the exact specifications for the device.
The datasheet lists the output voltage of the UT1404-7 as 30.5V.
