Accessories for cobs
------Question for BXRH-57S1001-G-74 Please Put your question below------
I just bought two of these. I’m wondering if you sell heat sinks, lens kits, and power supply’s/controllers/dimmers compatible with them? I tried looking around on your website but you have so many I can’t figure it out!
thanks!
Mark
I checked in our system, but I was unable to find any accessories recommended from the manufacturer. Checking on their website I was able this application note for assembly, and this application note for thermal management for their LEDs.
It depends somewhat on how one chooses to think about the question. If one’s looking for a neatly-bundled set of items specifically designed for interoperability and a lego-like assembly experience, the answer is no; such a thing doesn’t really exist as a matter of practicality and economics. Most folks just want to buy a light fixture rather than build their own…
If one’s in the DIY mood, the matter of picking the pieces and doing what’s needful to get them to stick together is entirely up to you. The LED Thermal Products family is a good place to look for heat sinks, but you’ll almost certainly end up needing to do some additional machining operations to accommodate your other selections.
The off-board LED driver family is a good place to look for drivers, and this post speaks to topics relating to selection of such.
Lenses and Reflectors often have interacting selection factors with the device used to mount and/or make electrical connections to the LED (typically found among the Optoelectronics Accessories) and unfortunately questions of compatibility are not very well documented. The respective optics suppliers’ sites often do a better job at this.
Thank you so much! That’s pretty much what I figured. Just thought you might have a better idea what goes with the thrive v6hd best component wise from experience. I spent the day researching power and controllers. Think I got it.
Right now I’ve spent 3 hours trying to find a solderless holder for the v6hd so I can attach it to a heat sink and I can’t find one anywhere. I went to all of bridgeluxs where to buy links and all over the web. I did send an email to bridgelux. It doesn’t seem any of the holders on your website are rated for the v6hd. Oh well …. Thanks again for taking the time to write a thorough response, it was most helpful!
Mark
