Accessories for Connector
I’m needing the correct female pins and strain relief for part# 1734-1214-ND.
Welcome to the DigiKey TechForum. Here is a good link with the different contact options available. You will need to select the contact based on the wire gauge size you will be using. Common Contacts for TE ICT Deutsch Housings - Interconnect - DigiKey TechForum - An Electronic Component and Engineering Solution Forum. The backshell is DigiKey part 1734-2428-025-1805-ND
