The Activity Status Indicator (ASI) is a manually controlled, USB-powered availability light for a desk or cubicle. This topic provides the mechanical design files and parts list for the project.
Several people asked me for a way to show approaching coworkers that they were in a digital meeting, on a phone call, or needed uninterrupted time. The ASI uses a single switch to display red for busy, green for available, or off for no displayed status.
A 3D-printed mount supports the illuminated panel, while a separate wired switch enclosure keeps the control within reach. Power comes from a standard USB-A port.
Project overview
See the finished installation and project description on Maker.io:
3D model downloads
The Switch Box
The Illuminated Indicator
SAI-CubicalClipSideA.step (153.0 KB)
SAI-CubicalClipSideB.step (123.8 KB)
SAI - CubicalClipCombiner.step (112.9 KB)
SAI-ModuleMountA.step (78.0 KB)
SAI-ModuleMountB.step (80.6 KB)
Parts list
| Component | DigiKey part number | Quantity |
| Four-conductor cable, 26 AWG, 1 m | T1290-1-ND | 1 |
| FIT0562 RGB LCD backlight module | 1738-1407-ND | 1 |
| USB-A cable with open wire ends, 1 m | A-USB20AM-OE-100BK28 | 1 |
| SPDT rocker switch | 2057-SW-R2-2E-F-6-2-ND | 1 |
| CFM12JT240R, 240 Ω ±5%, ½ W axial resistor | S240HCT-ND | 1 |
| Neodymium disc magnet, 25.4 mm diameter × 1.59 mm thick | 469-1032-ND | 1 |
If you build an ASI or adapt it to a different workspace, share your results or questions here.
