When looking for a AC to DC power supply, sometimes there isn’t a readily available solution with the required Voltage / Current output’s. In this case, we do have a configuration wizard on our site, that can provide all the parts needed to assemble the power supply.
This link Excelsys Configuration Tool (digikey.com) will bring you to the the configuration wizard as seen below.
For an example, I will use 10V @ 20Amps, 12V @ 30Amps, 6V @ 15Amps, and 7V @ 12Amps.
After the values are entered, click on “Configure Unit” and all the Manufacturers Part Number’s, quantity, instructions, and price will be listed as in the example below.
