AHD - NTSC Dev kit
I’m currently looking to develop a solution to convert an PAL/AHD signal to NTSC. Are there any good dev boards that would be a good starting point?
Hello 4efutures, welcome to the DigiKey TechForum.
The only eval board I found was EVAL-ADV7181DEBZ-ND, which can convert a PAL, NTSC, and SECAM standard to a digital ITU-R BT.656 format. I did not find one to go from PAL/AHD to NTSC.
