ALEV100-CSN (2040-ALEV100-CSN-ND) is a 24VDC chassis mounted contactor that has a SPST-NO (DM) (1 Form X) circuit layout made by Altran Magnetics. The current datasheet does not call out the “N” at the end of this part. A customer’s main concern was “Is this part still side mounted?”
Suffix Explanation
I did reach out to the manufacturer in this instance. They explained that the “N” indicates that the load terminal is non-polar (bi-directional). The “H” normally indicates a high voltage / high isolation version of the relay. The ending suffix does not modify the mounting detail.
