All things "Sticky" - 3M Adhesives!
#1
When you have a project that requires an adhesive, what are some of the first things you ask yourself?
Here are a few key points that should help you narrow down your adhesive choices.
  1. What is your substrate (materials that you will be bonding)?
    Stainless Steel, Foam, Powder Coated, Polypropylene, Polycarbonate, Aluminum, Wood, Plastics, Concrete, Stone, Glass, Ceramics, Fiberglass, Rubber, Brick, etc…
    Note: If using adhesive to put together two different substrates, this is important to note as well.
  2. What is your attribute?
  • Is this for general purpose, or high temperature - extreme colds. Constant temps, or variables.
  • Outdoor or indoor application.
  • Do you need it to be flexible, rigid, or permanent?
  • Is there a tensile, sheer, cleavage, or peel strength that is needed for your adhesive application?
Having an answer to these two questions, really helps to narrow down what 3M sticky product will work for your application. Remember to always look at the 3M Datasheets as they will provide you with a great deal of information on substrates.
So if your looking for Epoxy, Tape, Glue Sticks, Thermal Pads/Sheets or liquid adhesives - we have them all here at Digi-Key and available in Custom Die Cuts as well.
