Alternate Sources
Connector 38720-6203 is obsolete. I am trying to find a list of alternates in stock that have the same fit, form and function as this one.
Hi matthew.romero.
I couldn’t find an exact match for the obsolete barrier block, but 364-2138-ND should be a very close fit as a replacement. It has a slightly different body shape but according to the drawing it should mount exactly the same as 38720-6203 and handle the same power (it’s actually rated 5 amps higher.)
Jerry has a good alternate there; it looks like 364-2546-ND would also be very similar if you need multiple options for your list. I didn’t see anything that was a perfect match, either.
