I am looking for a cross reference to the following part:
Bosch Rexroth P/N R900223890
Description: IP67 Proportional Valve Connector, 7-pin (6 + PE), metal female cable connector per EN 175201-804.
Does Digi-Key offer a direct equivalent or compatible alternate that meets EN 175201-804 and IP67 requirements?
Hello @Linda
I can help search for a cross or alternative for this connector but may also require replacing both ends of the connection. If interested how is the mate mounted? Free hanging, Panel mount flange/bulkhead for examples. What is your outer jacket cable diameter and each wire gauge?
