Alternative to DS75492 MOS-to-LED Hex Digit Driver
Working through a book with several radio and electronics projects.
One of the parts listed is the DS75492 MOS-to-LED Hex Digit Driver.
Found a datasheet here:
https://www.digchip.com/datasheets/parts/datasheet/321/DS75452.php
Looking for an alternative since it does not show up in your extensive catalogue.
Thanks for your help.
Good Morning,
Thank you for your inquiry.
Take a look at part number SN75452BP to see if it would work in your application.
Welcome to the forum.
The link you posted is for a DS75452 and @TechForum gave a good potential substitute for that.
However your text says you are looking for a DS75492 MOS-to-LED Hex Digit Driver. Jameco has some available of the generic version (SN75492N actual manufacturer not specified).
https://www.jameco.com/z/75492-Major-Brands-5-VOLT-HEX-DIGIT-DRIVER-DIP-14_51131.html
Thanks @PaulHutch and @TechForum for the responses.
I see that I provided the wrong link as I was trying to look for alternatives. I am in fact looking for a alternative for
I will check out your suggestion @PaulHutch
Thanks everyone.
