Hi there,
I was just wondering if is possible to source the mentioned contactors?
I am looking for AREV-100NC-SN. I see DigiKey provide other Altran Magnetics contactors, so I am wondering if these are obtainable?
AREV100_DataSheet_04March2026.pdf (1.9 MB)
Datasheet attached.
Thank you!
@helge.stewart_digike
Looking over the data-sheet you like the item number you list seems to be missing the coil voltage.
– What voltage would you like?
– Would you happen to have the link to the web-page that PDF is listed on the manufacturer’s site?
– How many were you wanting to have quoted?
Hi Nathan,
I would need the 12V version. So I guess AREV100NC-ABSN would be correct, seen as I would like the 12V coil, NC version, with a NO aux contact, side mount and non polarized contacts. The datasheet was provided to me by Altran directly, I have not found any of the AREV-series on their website, so maybe the website is not updated.
I would need 2 for now, so not a big order in that regard.
Thank you for your help so far.
After some considerations I have found that I do not NEED the side mount option, so if it is not available that is fine.
So either AREV100NC-BASN or AREV100NC-BAN
It would seem that there is some work being done to add some of the AREV100 relays to our site and should be listed in a few days. I am sorry to say that I don’t have a specific ETA on this.
That is great, I have time to wait. Thank you for the update!
Out of curiosity, are we talking “a couple of days” like sometime this week or the next, or more like “by the end of May/start of June”??
It can be a week to two depending on how long the rest of the items take to be added to the site.
However, the AREV100NC-BASN and AREV100NC-BAN are being added with the other parts being added.
Lovely!
Thank you for your help!
Hi again Nathan,
I have been checking back regularly, and there seems to only be the initial 6 relays added, the aforementioned AREV100NC-BASN or AREV100NC-BAN are not to be found. Are you able to provide a lead time for these?
Thank you.
I am sorry for the delay on this.
I have submitted an inquiry to the team that handles adding these to see where it is at.
We are nearing the end of June, a search for AREV100NC yields the same result as it did the day after your “In a week or two depending…” reply above.
I realize you are not in charge of this, and it is not your fault, but there must be some way to get an accurate ETA for the aforementioned parts added to the inventory.
Do I have to go to alternate sources for this part?
Contacting orders@digikey.com to request an ETA would be the best to get a date for when the AREV100NC parts will be in stock.
Otherwise adding your email to the get notified when in stock can done.
Thank you for your reply, but I do not believe you read the whole thread, if you did, you must have misunderstood. The 6 AREV100NC relays that are listed on the store, but out of stock, are not the one(s) I am looking for. I am looking for AREV100NC-BASN or AREV100NC-BAN, which has not yet been added to the store. Nathan told me, on the 23rd of April, that the above mentioned part numbers where about to be added to the store soon (within weeks), it has now been close to 2 months, and they are still not added.
All I would like to have is a little bit more exact a time-frame for when I could happen to find them on the store.
I`ll shoot an email off to the address you provided, again… Maybe something changed, because they sent me over here for answers when I asked for this exact same thing on the 15th of April.
I have now done as you said, contacted orders@digikey.com, but they just send me right back here, as I suspected. They did say this tho:
At this time, we are unable to confirm whether or when these specific variants will be added to DigiKey’s catalog. As the parts are not currently listed on our website, we do not have access to availability, lead-time, or sourcing information for them through our order-entry system.
For the most accurate and up-to-date information regarding these specific part variants and any potential future catalog additions, we kindly recommend continuing the discussion through the DigiKey TechForum, where our technical specialists can review product-specific inquiries and provide guidance regarding manufacturer offerings and potential alternatives. Please visit: DigiKey TechForum - An Electronic Component and Engineering Solution Forum
So I am back here… again.
Does anyone have any other information, maybe alternative products? I needed this at the end of May, but that deadline is long gone now.
The below link shows the options we list that are at all similar to the original items
Contactors (Electromechanical) | Relays | DigiKey
I am sorry to say that I did not find an option that would match the requirements of the AREV100NC-BASN or the AREV100NC-BAN directly.
Had a check back today and found that the relays in question now indeed have been added to the store. Took a little while longer than initially expected. I`ll leave a link below, for future reference, and mark the topic as solved.
Thank you for your help @Nathan_2268 and @Steven_14444
AREV100 Series
