------Question for 114990711 Please Put your question below------
What is the maximum power in dbm that the 114990711 Antenna - RF ANT 3.5GHZ LOOP SMA FEM CONN - can handle? Is there a similar loop probe with high power tolerance?
Hello @gwitt,
Thank you for your post.
The manufacturer does not come out directly stating it’s maximum capabilities in regard to power ratings.
There is some information on their datasheet that may help - RFExplorerRFEAH_25datasheet.pdf
Unfortunately, I do not see an alternate in that same style.
Hello @Brent_2328 ,
Thank you for the reply and information. Is it possible to reach out to the manufacturer? Or should I perhaps reach out myself? I’m a little worried about accidentally pumping too much power into this.
Thank you!
You can try and reach out to the supplier. If you’re unable to get ahold of them, please let us know ane we can try another way.
