Are these shielded?
------Question for CP30700GMB3 Please Put your question below------
Are these shielded?
Hello sundancepd,
As I understand the CP30700GMB3 product, the HDMI connectors are shielded within a plastic enclosure.
The connectors themselves will be shielded (front to back). As a result, the entire assembly will appear as a single shielded cable from the source to the destination.
Tech Tip: There will be some attenuation in the connector. As a consequence, we should not expect operation at the maximum nominal 50 feet (15 M) cable length.
Best wishes,
