------Question for ESP32-DEVKITC-VE Please Put your question below------
I see there is no arial connection on this dev board. The PCB arial is also not connected. Should I solder on a U.FL myself?
The dev kit 1965-ESP32-DEVKITC-VE-ND does not come with the U.FL antenna, it is only the PCB antenna.
For the dev kit that come with the IPEX connector, you will need to order the 1965-ESP32-DEVKITC-VIE-ND. Otherwise you can solder on your own, if you choose to.
