Associated Products/Mating Connectors
When searching for products on the Digi-Key website, it can be easy to find yourself down a rabbit hole. Especially if you are looking for the mating connector to a circular connector, an associated pin, or accessory. For example, when you pull up Digi-Key part number SC1210-ND (Conxall/Switchcraft part number 18282-2PG-311)
When you first land on this page, you will see the datasheet, pricing, availability, and some other information about the part. As seen here:
You will need to scroll down underneath the Product Attributes as well as the Documents and Media. This is where we come to the Mating products shown here:
This webpage is quite long, an easy way to get here is to click the more documentation at the top of the page under the datasheet. It will automatically scroll you down to the Documents and Media section.
Other associated products from the manufacturer can be seen underneath the mating products:
I know I specifically used SC1210-ND but this layout is general to the Digi-Key website. Here is another example, in our battery category part number N189-ND (Energizer Battery Company part number CR2032VP) you will see a For Use With section (similar to the mating section) as well as the Associated Product. Shown here:
As always, if you have any questions or need assistance we are available to LiveChat.
