I’ve got an ASUS ROG ALLY X, the unit had a loose screw fall into it while powered and damaged a chip. The chip is labeled BCGLYA, and other documentation suggests it is likely a Silergy synchronous step-down converter. I’ve attached a photo.
I can’t find the component anywhere, is there anything compatible I can use instead? Any advice is appreciated.
