ATIGG1040-1 EOL?
------Question for ATIGG1040-1 Please Put your question below------
Is this product at EOL? It’s not readily available through many channels and leadtime is long. I’d also love input on a drop in sub if anyone has one.
Not sure about EOL, YIC dont publish it clearly. Better ask DigiKey to check with the factory.
For drop in sub - its active patch antenna on cable with IPEX, so there is no true one-to-one part. Match 1) GPS+GLONASS band, 2) LNA gain and supply voltage your receiver gives on RF line, 3) cable length and connector, 4) patch size if it sits inside enclosure.
Honestly for antennas I would not hunt exact clone. Qualify two options in your enclosure once and put both in BOM. What receiver and enclosure are you using?
Hello @lindsey.baird, thank you for your question.
Nothing indicates the YIC ATIGG1040-1 (3155-ATIGG1040-1-ND) is EOL. It’s listed as Active with a 13-week manufacturer lead time.
Please review the TE Connectivity Linx ANT-GNCP-CA158L160 (343-ANT-GNCP-CA158L160-ND): GPS/GLONASS, 15 dB LNA, 60 mm cable, U.FL/MHF1 connector. Note that it’s larger (15 x 15 mm), and needs a 3.3 V max antenna supply.
ANT-GNCP-CA158L160 Datasheet
Please review the datasheets to ensure the alternative will work for your application.
