Condenser evaporator which end. The data sheet doesn’t say.
Weclome to the Technical Forum. I have sent this to the Product Specialist for some help. I did not see anything in the documentation.
The datasheet doesn’t indicate which end is which, because the internal fluid flows can change direction depending on the temperature gradient between the two ends; whichever one is warmer becomes the evaporator, the other the condenser.
Ok. That answers my question. Thank you.
