AW08-G300 I would like to know if there is any way to convert it to Wi-Fi
------Question for AW08-G300 Please Put your question below------
Good afternoon,
I have a device, model AW08-G300, which currently operates via Ethernet. I would like to know if there is any way to convert it to Wi-Fi — for example, through a compatible wireless antenna or adapter — and whether you offer such accessories.
I would appreciate any information you can provide.
Kind regards.
Thank you for contacting DigiKey Technical support.
IT does see, to be possible for part number AW08-G300 to work with WiFi. It is if more of a process then just hooking a WiFi antenna to it. I will asked my team about your question and get back you you.
Per the datasheet on the product page, it appears the the models with built-in wireless connectivity are the -W300 unites. The-G300 model does not include this functionality and would not be directly adaptable to wireless use.
