B B Battery HR9-6 Rechargeable Batteries - suffix detail
For B B Battery’s HR9-6 series of rechargeable batteries, there are suffixes on the part numbers that are not called out in the manufacturer’s datasheet. HR9-6 only defines the battery product type.
You may see the below two part number options
HR9-6-T2 is the most common option with a .250” (6.25mm) width terminal, while HR9-6-T1 has a .19” (4.75mm) width Terminal.
