B&K Precision, LCR Meter 880: Accessories?
B&K Precision sells a selection of testing equipment, such as their 880 LCR meter. Recently, we’ve had a few inquiries into the accessories that this device ships with. Does it come with everything it needs, and if not which extra products do you need to buy?
Fortunately, the 880-series model comes with everything it needs to function. Per B&K’s datasheet, the 880 model comes with an AC adapter for charging, alligator test leads, a USB cable, Kelvin clip test leads, an SMD tweezer test lead for use with surface-mounted PCB components, and a shorting plate.
