Hello
Looking for a DIN rail timer to backwash a sand filter at a small remote resort.
Two side by side (parallel) cycles twice a day (3am and 3:30am) as follows;
First parallel cycle, on for 5 minutes 20 seconds
Second parallel cycle, on as follows; pump on 5 seconds, off 5 seconds, pump on 5 minutes, off 10 seconds.
Notes
The first train simply does.Upon activation it disconnects the pumps from all other timed and demand settings, giving exclusive authority to the backwash system, upon the 5m 20s timeout it de-energises and releases pump authority to alternation relay, fire system and safety circuits.
The second train works as follows.The first 5 seconds on starts hydraulic valves to opening, the second 5 seconds (off) allows valves to settle into backwash position, then 5 minutes of pump doing the backwash followed by 10 seconds with pump off to allow sand to settle.
Thank you
