Batch Processing Multiple Files into Combined PSD/Grms Calculation - enDAQ S3-E100D40
Hi everyone,
I’m using the enDAQ S3-E100D40 data logger and have collected vibration data across several hundred files.
I would like to convert this data into PSD (Power Spectral Density) and calculate the Grms value. However, in the current software, I can only generate a PSD plot for one file at a time.
Is there a way to combine or batch process multiple files together to generate a single PSD plot (instead of processing them one by one)?
Any guidance or suggestions would be greatly appreciated. Thank you!
Greetings,
An answer to such a question likely depends on one’s toolset and comfort zone boundaries as much as anything.
I’m not sure that anybody on this side of the screen has sufficient familiarity with the software package in question to be able to confirm or deny availability of any sort of built-in batching function, or identify a convenient means of bolting one on.
That said, a third party math package such as Matlab or its open-source counterparts could be a reasonable tool for such analyses, with the added benefit of giving a person greater control over the specifics of the process.
