I’m wanting to order a replacement for my JBL7452122500103FJ Battery charger it appears there is a new part # JBL7452122500003FJ is the compatible with my old charger?
Hello deana.cook, welcome to the TechForum.
Unfortunately I could not verify part number JBL7452122500103FJ anywhere.
Hello Deana,
Thank you for again for posting on the TechForum.
Part number JBL7452122500003FJ-ND is the closest match I was able to find.
I would ask that you take note of the connector on your power supply. The difference between the parts could be the connector. Also note that part JBL7452122500003FJ-ND is non-stocking and has a minimum order quantity of 250pcs.
The connector looks to be bigger than the 2.5mm ID on the JBL7452122500003FJ.
How to tell the size of a barrel plug.
The barrel on your power supply was most likely a custom request from the OEM that your charger is for hence the difference in the part number.
