For BEL (former Cinch/Stewart) HDMI cables BC-Hxxxxx series, the dimension of the cable strain relief region for Male HDMI connector is not documented
Sometimes it is important to know this dimension if the Male side of the cable is inserted into cable holder/fastener like in below picture
As per the manufacturer:
The outer diameter of the raw cable and the dimensions of the strain relief region of the PVC overmold on the HDMI plug are as follows:
Cable OD: Ø7.30 ±0.15mm
Largest diameter of strain relief: Ø11.14±0.50mm
Smallest diameter of strain relief: Ø10.36±0.50mm
Length of strain relief: 9.93±0.50mm
