I am trying to program a BLUENRG-M2SA with a led flashing program. It works if I am using Keil. It compiles but is not working with the new code in Atollic True studio. Do you need to flash a BLUENRG-M2SA in Atollic a pro-license.
So a few years back, ST purchased the company behind Atollic studio and rolled it into STM32CubeIDE, as long as you ‘register’ thru the tool (about → etc…) it should be fully enabled.
Regards,
I am registered through CubeMX. The BLUENRG-2 is not on the CubeMX neither is an about option.
Is it Atollic I need to register through. It doesn’t have an about option either.
Regards
