Bluetooth board size
------Question for 333353 Please Put your question below------size measurements in mm please
Hello brucelfinn,
Welcome to the DigiKey Techforum!
I could not find documentation on the manufacturer’s website that specifies the dimensions of this breakout board. I will contact Soldered Electronics for this information and follow up with you.
Caleb,
Thank you, I am making a wearable device that powers a small 5" strip off 3.7V LED’s dith a 75mAh lipo battery and I need a tiny wireless controller to turn it off and on. Any suggestions would be appreciated.
Bruce Finn
Hello brucelfinn,
The dimensions are 38mm x 38mm x 3.8mm, with the holes being M3 size, 3.2mm diameter.
