Building a FOC Stepper Motor Controller with the MAX32672 Feather Board
Introduction
This project is a journey towards building a Field-Oriented Control (FOC) stepper motor controller based on the MAX32672 Feather Board. The goal is to create a compact, high-performance, closed-loop motor controller suitable for applications such as CNC machines, robotics, and distributed motion control systems.
I received the MAX32672 Feather Board as part of the “Learn, Build & Win” program organized by DigiKey in collaboration with Circuit Digest and supported by Analog Devices. The program selects participants based on their project proposals and provides them with development hardware to learn and build their ideas.
Special thanks to DigiKey, Circuit Digest, and Analog Devices for providing the opportunity and the hardware to explore advanced motor control and embedded systems.
I will be documenting the progress of this project in this thread as the hardware and firmware evolve.
Project Goals
- Implement closed-loop FOC for hybrid stepper motors.
- Achieve smooth operation with reduced vibration and resonance.
- Build a distributed motor control architecture suitable for multi-axis CNC systems.
- Utilize the DSP and floating-point capabilities of the MAX32672 for efficient real-time control.
- Integrate current sensing, encoder feedback, and fault detection.
Hardware Used
Controller
- MAX32672 Feather Board
- Development using MaximSDK (MSDK) with VS Code
Motor Driver
Current prototype:
- A4953 Dual H-Bridge Driver
Future plans:
- Evaluate higher-power driver stages if required.
Current Sensing
Current prototype:
- INA180 Current Sense Amplifier
Planned upgrade:
- INA240 Current Sense Amplifier
- Better common-mode transient rejection
- More suitable for PWM motor control applications
Position Feedback
Current prototype:
- AS5047P Magnetic Encoder Module
Future plans:
- Integrate the AS5047P IC directly onto the controller PCB.
Why the MAX32672?
Motor control requires significant mathematical computation and fast signal acquisition. The MAX32672 offers several features that make it an excellent platform for FOC applications:
- ARM Cortex-M4F running at up to 100 MHz
- Hardware Floating Point Unit (FPU)
- DSP/SIMD instructions
- 1 MB Flash and 200 KB SRAM
- High-speed 12-bit ADC with up to 1 Msps sampling
- Multiple SPI interfaces
- Low-power architecture
These capabilities make it possible to efficiently implement:
- Clarke Transform
- Park Transform
- PI current control loops
- Position and velocity control
- Filtering and signal processing
- Future condition monitoring algorithms
Development Progress
Stage 1: Encoder Bring-Up
Hardware
Development Environment
- MaximSDK (MSDK)
- VS Code
Communication Interface
- SPI
Status
SPI communication established
Successfully reading angular position
Continuous position updates verified
Current Test Setup
Example Output
Angle: 0.00°
Angle: 17.62°
Angle: 91.48°
Angle: 181.32°
Angle: 359.92°
The encoder communication is working reliably and provides smooth position feedback. This marks the first major milestone toward implementing closed-loop FOC.
Next Stage: Current Sensing
Hardware
Objectives
- Measure phase currents
- Characterize ADC performance
- Validate current feedback signals
- Prepare for current control loops
Future Upgrade
- INA240 Current Sense Amplifier for improved PWM rejection and measurement accuracy.
Future Development
Current Control
- ADC synchronization
- Offset calibration
- Current filtering
FOC Implementation
- Clarke Transform
- Park Transform
- PI Current Controllers
- Space Vector PWM
Closed-Loop Motion Control
- Torque control
- Velocity control
- Position control
Hardware Integration
Move from evaluation modules to a custom PCB containing:
- MAX32672
- AS5047P IC
- INA240 current sensing
- H-bridge driver stage
- Communication interface
Distributed Motion Control
Long-term plans include networking multiple motor controllers together to create a distributed control architecture for CNC machines and robotics.
Current Status
| Feature | Status |
| Development Environment | Working |
| SPI Communication | Working |
| AS5047P Interface | Working |
| Angular Position Feedback | Working |
| Current Sensing | In Progress |
| FOC Current Loop | Planned |
| SVPWM | Planned |
| Closed-Loop Stepper Control | Planned |
| Custom PCB | Planned |
Acknowledgements
This project is being developed as part of the Learn, Build & Win program organized by DigiKey and Circuit Digest, with hardware support from Analog Devices.
A special thanks to:
- DigiKey for supporting makers and engineers through initiatives like this.
- Circuit Digest for organizing the program and fostering a community of learners and builders.
- Analog Devices for providing the MAX32672 Feather Board and enabling experimentation with advanced embedded systems and motor control.
I’ll continue updating this thread as I progress through current sensing, PWM generation, and eventually closed-loop FOC implementation. Feedback and suggestions are always welcome!
