------Question for SAS-115-075-1017-1X Please Put your question below------ Subject: Bulk Packaging & Lead Time Question - SAS-115-075-1017-1X.
I need to order a large quantity of SAS-115-075-1017-1X (Split Adhesive Sleeve, 0.75" length) for a project requiring approximately 20,000 pieces. I have a few packaging and timing questions:
What is the standard factory packaging quantity for this part number? I see references to 1,000-piece packs, but wanted to confirm.
For an order of 20,000 pieces, can these be packaged in larger bulk quantities (e.g., boxes of 5,000 pieces) rather than multiple smaller packages?
What is the typical lead time for an order of 20,000 pieces? Is this quantity readily available, or would it need to be special ordered from the manufacturer?
Is there a volume discount available for quantities in the 20,000-piece range?
Does the part number SAS-115-075-1017-1X correspond to the same specifications as SAS-115-0.75-1017, or are there differences I should be aware of?
I’m trying to determine the most cost-effective approach and ensure I can meet my project timeline. Any guidance would be greatly appreciated.
Thank you!
