Hi, do you know if there is a heat sink available for this LED bar? Thanks a lot. BXEB-TL-L1120Z-2750S4000-A-C3
Welcome to the DigiKey TechForum. Here is an application note from Bridgelux with information on thermal management for BXEB-TL-L1120Z-2750S4000-A-C3 starting on page 17. They state “these products generally do not need heatsinking like other products with higher power densities do.” so there is no designated/associated heatsink available for these strips. There will be heat generation and Bridgelux does recommend building a prototype and measuring the case temperature under worst-case conditions to determine if heatsinking is required.
